-Easily switch on/off via iPhone, iPad, Android -Manual or scheduled controls -Email notifications after switching on/off -Wireless installation using a smart phone/tablet
Edimax Smart Plugs connect people to their homes, and the things they use every day. Designed to make homes more dynamic, functional and work better for modern lifestyles, Smart Plug products give users intelligent control over all of their home electronics. The Smart Plug Switch plugs into any wall socket and enables you to switch or schedule a connected electronic device on/off from your smartphone. Just plug the device into the Switch and see how Smart Plugs can work for you and your home.
Intelligent Home A Smart Plug Switch is just the beginning. Add more Smart Plug products and bring your home to life in imaginative, inventive ways - it's up to you. Our Smart Plug home management app can monitor, control and schedule all of the electronic devices connected to Smart Plug Switches around your home.
Control, check, convenience
Switch on the lights, coffee machine, Xbox, or anything you want - from your smartphone. Check the status while you're out and switch them on or off anywhere, anytime. Never worry about forgetting to turn something off when you go out again. Smart Plugs are super-fast and stays connected 24/7.
Schedule, save
Program intelligent schedules to make your home smarter and more energy efficient. Our Smart Plug Switch was developed to suit your lifestyle. Schedule your lights so it's light when you get home or when you wake up in the morning. Schedule your lamp or coffee machine if you like - Smart Plugs can schedule anything in your home to work in better ways for you and your life.
Easy setup & smart notifications
Setup couldn't be any easier and is all done on your smartphone or tablet. Once the Smart Plug is up and running, email notifications can keep you updated about which appliances and electronics are switched on/off via the EdiPlug app. Make sure your intelligent home is working properly and keep track of what's going on in a busy, family home.
Edimax Smart Plug Switch SP-1101W - power control unit
Power control unit - external
184 g
Input Voltage
AC 100-240 V
IEEE 802.11 b/g/n
Remote Management Protocol
HTTP
6.4 cm x 6 cm x 10.5 cm
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Remote Management Interface
IEEE 802.11 b/g/n
HTTP
LED indicators, email alerts support, firmware upgradable, remote ON/OFF function
