The Edimax IC-3030i series is tailor made to stream live video footage of your home wired or wirelessly over a network connection. You can check upon the security of your home, family, pets, or assets with the bundled viewer, which allows you access up to 16 Edimax network cameras simultaneously.
The Edimax IC-3030i series is perfect for capturing brilliant and clear video images under low light conditions. What makes it suitable for operating in such environments is its built-in IR (infrared) LEDs and light sensor. The IR LEDs are able to illuminate up to 4 meters effectively, making the IC-3030i series suitable for almost all security and surveillance applications.
