300Mbps Wireless ADSL2/2+ Modem Router The Edimax AR-7286WnA/B is a high performance router that provides full ADSL2+ capability and superb reliability as a cost-effective networking solution for homes and small businesses.
Compatible with the wireless standard 802.11n, and with advanced MIMO technology, the AR-7286WnA/B provides up to six times better data transmission rates (up to 300Mbps) and five times better coverage than a standard 802.11g/b router.
All-in-One Device The AR-7286WnA/B is a wireless N router with a built-in ADSL2/ADSL2+ modem combining a high-performance router, modem, and a switch into a single device. Save desk space, the hassle of extra cords & cables and the cost of leasing a router from your DSL service provider.
Powerful and Wide Coverage Featuring two 5dBi high-gain antennas, the AR-7286WnA/B boosts your signal to ensure extended wireless networking range. Four-Networks-in-One The AR-7286WnA/B supports multiple SSIDs for up to four wireless networks.
Lightning Protection Protected from lightning strikes to help your device avoid the damage of a tough thunderstorm.
Supports TR-069 for Remote Management The AR-7286WnA/B also supports TR-069 which is a protocol to define a common method for CPE devices to communicate with a server.
Wi-Fi Protected Setup (WPS) Wi-Fi Protected Setup is a quick and convenient method of establishing wireless connections between compatible devices. Set up a wireless network in less than a minute with just a couple of clicks of a button or easily add new Wi-Fi devices to an existing network.
Easy Setup Wizard with Built-in ISP Selector Setup the ADSL modem router using the unique and convenient multi-language setup wizard provided on the included CD-ROM or available through a web browser. Select your language and follow a few simple steps to setup the router and configure the Internet connection, password, SSID and wireless security. Additionally, the setup wizard includes a built-in ISP selector to configure your ISP settings automatically.
