AC600 Multi-Function Dual-Band Wi-Fi Router,Access Point, Range Extender, Wi-Fi Bridge & WISP
To meet today’s high-speed connectivity needs, Edimax has launched the BR-6288ACL dual-band 802.11ac router with the latest 11ac standard for extraordinary improvements in the speed, reliability and quality of wireless communications. It’s a 5-in-1 dual-band Wi-Fi router with an easy 3-step setup using a smartphone app or web-based smart iQ setup, which meets all of your Wi-Fi demands and is the first product of its kind to feature a green, power-saving TX power switch to adjust the Wi-Fi signal strength. The smartphone app and web-based interface also support auto firmware upgrade and the sleek design provides a unique, space-saving aesthetic which blends with any interior and delivers wide-reaching Wi-Fi coverage.
- Next generation 802.11ac Wi-Fi standard
- 5-in-1 Router, Access Point, Range Extender, Wireless Bridge and WISP
- Backward compatible with 802.11a/b/g/n standards
- Concurrent dual-band wireless connectivity for 2.4GHz and 5GHz
- Smartphone App & Smart iQ Setup
- Auto Firmware Upgrade
- Green Wi-Fi TX Power Switch
- High gain internal antenna for better Wi-Fi performance
- Supports up to 8 Multi-SSID (2.4GHz x 4 and 5GHz x 4) & VLAN (AP mode only)
- Supports guest network (router mode only)
- Revolutionary iQoS for efficient and effective internet bandwidth management
- Powered by USB
