An extended battery module (EBM) giving additional runtime for Eaton 9130 5000and 6000 Tower UPS. Up to 4 EBMs can be attached to each UPS in order to increase runtime.
Double conversion topology. The 9130 constantly monitors power conditions and regulates voltage and frequency. Even when presented with the most severe power problems, UPS's output remains within 3% of nominal voltage. More real power. High 0.9 output power factor enables the 9130 to provide its full power capability to modern IT equipment. Highest efficiency to reduce utility and cooling spending. The 9130 can provide up to 95% efficiency in online double conversion mode and up to 98% in high-efficiency mode.
Unmatched reliability
Stronger, longer battery lift. Eaton ABM battery management technology users an innovative three stage charging technique, that only recharges the battery when necessary, so the battery experience less corrosion and service life is prolonged by up to 50%. Batteries can be hot-swapped without ever having to shut down connected equipment. It offers possibility to add more runtime at any time with up to four external hot-swappable battery modules to run systems for hours if necessary.
Outstanding versatility
One platform, two factors, dozens of choices. Up to 3000 VA of UPS power is packed into only 2U of rack space. The tower option is about the size of a modern, compact PC. It enhanced configuration capability through easily navigated multilingual graphical display.
