Redesigned from the ground up to meet the data storage needs of today's media creators and demanding professionals, Drobo 5D builds on the fully automated functionality of previous Drobos by adding blazing-fast performance. Leveraging cutting-edge Thunderbolt and USB 3.0 connectivity - along with the innovative use of solid state drives (SSDs) - Drobo 5D is the highest-performing personal storage array on the planet. Not only is Drobo 5D fast, but it's easy-to-use, expandable, flexible, and protected - exactly what's expected from a Drobo. You can safely store and edit photos and videos as well as store and back up personal data.
Usually reserved for larger enterprise-class storage solutions, the Drobo 5N2 gives you the option to implement Hot Data Caching through the Drobo Accelerator Bay. This feature intelligently uses high-performance flash to accelerate performance, allowing the fastest possible access to your data.
Dual Ethernet ports: bond together, or failover
The 5N2 has dual Gigabit Ethernet ports. These can be bonded together to provide approximately twice the read/write performance you get via a single port. Or they can be used to provide a connection to two different subnets. Furthermore, they can be used in an "active/passive" mode so that if one port fails the other takes over.
Drobo disaster recovery
With DroboDR you can set up a pair of 5N2s to automatically make an offsite copy of your data. Simple to set up and manage, the reliable DroboDR seamlessly replicates your data to another 5N2 ensuring data availability in case of disaster. Even better, the remote 5N2 stores all user account information so recovery is painless.
Power protecting your critical data
The Drobo 5N2 doesn't just protect from drive failures, it also includes a battery backup system that protects all data in memory or cache. That's right, Enterprise grade data protection for you on your Drobo 5N2! If power spontaneously goes away, the Drobo stays alive long enough for the data to be written to disk, ensuring your important information is always safe. The onboard battery recharges itself and is designed to last for the life of the product.
Drobo 5N2 - NAS server - 10 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
10 TB
Storage Capacity Details
Volume capacity: 64 TB
Max Supported Capacity
50 TB
5 (installed) / 5 (max)
15.03 cm x 26.23 cm x 18.54 cm
3.9 kg ()
Storage Controller
SATA SATA 6Gb/s
Hard Drive
5 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.10 or later
NAS server
Host Connectivity
Gigabit Ethernet
10 TB
50 TB
15.03 cm
26.23 cm
18.54 cm
3.9 kg ()
Built-in Devices
Led panel
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
HDD
5 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
SMB
Network Services Compatibility
Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
Apple Time Machine compatible, failover protection, Jumbo Frames support (up to 9000 bytes), Adaptive Link Bonding, secure backup, remote data access and sharing, Disaster Recovery technology
Expansion Bays
5 (total) / 5 (free) x hot-swap - 3.5" , 1 (total) / 1 (free) x internal - mSATA
2 x Ethernet 1000Base-T - RJ-45
2 x network cable - 1.8 m
Security lock slot (cable lock sold separately), BeyondRAID technology, built-in cooling fan, automatic fan speed control, backup battery, carrier-less drive bays, power fail protection
Security Slot Type
Kensington security slot
External power adapter
Power Provided
84 Watt - 7 A - 12 V
Software Included
Drivers & Utilities, Drobo Dashboard, DroboApps
