VigorSwitch G2280x
10GbE Gigabit Switch with 24 Gigabit Ports & 4 10GbE SFP+ Uplink Ports
The VigorSwitch G2280x is a high-performance, L2+ Managed Gigabit Ethernet switch. With 24 1-Gigabit RJ-45 LAN ports and 4 10-Gigabit Ethernet SFP+ ports.
Use the 4 SFP+ ports for high speed uplinks between Switches, Servers and Network-Attached-Storage at up to 10 Gigabits per port.
Designed for centralised management, the VigorSwitch G2280x can be managed directly through its web interface, or provisioned and monitored through both the VigorACS management platform and/or, a DrayTek Vigor router’s Central Switch Management. Easily provision the VLAN configuration through the router and clone switch configurations. Drastically reduce the setup time required for a complex network, with VLANs spanning multiple switches.
10GbE SFP+ Ports for High Speed Uplinks
Advanced Layer 2+ Routing Features
Quiet Operation & Hardware Monitoring
Quality of Service & Bandwidth Control
Network Security and Management Features
ONVIF IP Camera Management
Central Management
Managing a VigorSwitch through VigorACS
Central Switch Management with a DrayTek Vigor Router
Energy Efficient Ethernet
Rack Mountable & Silent
IP Conflict Prevention
