| Quicklinx: | D69ZWS00 |
| Mfr#: | V2862AC-K |
The Vigor 2862 series is their flagship router/firewall. As well as ADSL/VDSL support, alternative WAN ports can instead provide connectivity to Ethenet feeds (Gigabit WAN2 is switchable with LAN Port 5), secondary xDSL modems or a 3G/4G cellular service using a supported USB adapter. These multiple LAN feeds can be combined for failover or load-balancing.
This router series includes support for other professional features such as VLAN tagging, QoS (Quality of Service Assurance), High Availability, DNS Filter, Policy Based Routing, and User Access Control. Hotspot features with customisable branding and wording which can be applied to guest network VLANs & SSIDs. If you deploy DrayTek Wireless Access Points, the Vigor 2862 can act as the Central Management controller (click on any of those links for an explanation of each feature).
A 5-port Gigabit Ethernet switch on the LAN side provides high speed connectivity for your server, other local PCs or for uplink to a larger Ethernet switch. Comprehensive security features include content filtering, web application controls and an object based firewall management system. Port 5 is switchable with "WAN2" to use it as an Ethernet WAN port instead of a LAN port.
