The Vigor 2820 series is DrayTek's flagship premium ADSL router/firewall family. PC Pro says "For business, it's an obvious choice".Compatible with all variants of ADSL the Vigor 2820 can also be used for cable-modem and leased line applications thanks to its additional WAN port (Ethernet). A Gigabit Ethernet port on the LAN side provides high speed connectivity for your server. Security features include content filtering, web application controls and an object based firewall management system.
Write a review for the DrayTek Vigor 2820n Wireless-N Router BT ADSL here!
s
Ive had one since December and like all the other Drayteks I have owned over the last 10? years it was simple to set up and works perfectly. Im here today to buy another one for my dad which replace his aeging Vigor2600+. Ive tried all brands and Draytek are the best IMHO. My X had a really crappy (BT) ADSL broadband connection, no router would work with it. BT said the service was fine haha. Only the Draytek would pick up a signal and allow a diagnostic. The BT router and a Dlink router.. (which I rate to be a decent cheap router by the way) failed to get any signal. Ive never tried a Cisco yet so maybe a better router than the Draytek exists but Cisco are mega bucks? Buy Draytek and scorn all lesser makes.
I now have 11 of these in remote student houses and they are by far the best I have used so far (and I've tried most!). Excellent reliability and web interface for troubleshooting. Bit pricey but highly recommended if you need something that works. I have not had the problem with the DHCP server mentioned in another review.
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
