            Draytek ANT-2520 is a dual-band indoor directional patch antenna. It is used for normal indoor point-to-point wireless connection applications. ANT-2520 is designed to connect with most wireless devices that use a detachable antenna. Simply unscrew the existing antenna on your device, connect to the Draytek high-gain antenna and enjoy the benefits of wireless network.
