A notebook can be stolen in an instant. Expensive hardware and important data are lost. This can involve a lot of work and great expense. Police, insurance, data recovery etc. Targeted prevention is the answer - with a quality lock from DICOTA. The Security T-Lock Retractable convinces with its functional and compact construction design. With the push of a button the cable can be rolled up for convenient transportation. Easy and ideal during travel.
Notebooks as well as projectors, monitors and printers can be effectively secured with the DICOTA locking systems. Currently, device manufacturers use three different formats for the lock slots. The Security T-Lock Retractable is suitable for all models with the commonly used 3 x 7 mm slot. Using the three different spacers supplied it can optimally accommodate housings of varying thicknesses and ensures a seamless fit for your device. Enjoy high flexibility in workplace design - both the cylinder as well as the closing head itself can be fully rotated. Thanks to the push-to-lock function, the lock can be secured without a key using one hand. Quick, simple and reliable. The sheathed multi-strand steel cable is 1.3 m long and has a diameter of 2.4 mm. Two keys are included as part of the delivery.
