            Notebooks are becoming narrower and at the same time more powerful. The lightweight and particularly slim Ultra Slim Locks reliably protect your device without unnecessary application. Projectors, monitors or printers can also be effectively secured with the DICOTA locking systems. The device manufacturers currently use three different formats for the lock slots. The Security Cable Nano Lock Ultra Slim fits all devices with a 2.5 x 6 mm slot and is compatible with the Kensington Nano Security Slotâ„¢*.
A foam buffer prevents scratch marks on the device. With the rotatable and swivelling locking head, you enjoy great flexibility in workplace design. Thanks to the push-to-lock function, the lock can also be attached without a key and with just one hand. Fast, easy and secure. The framed multi-strand steel cable is 2 m long and has a diameter of 4.4 mm. With the practical Velcro tab, the cable can be rolled up for transport and storage in a space-saving manner. Two keys are included in the scope of delivery. This lock is a single-user version and cannot be integrated into a higher-level locking system. *Nano Security Slotâ„¢ is a trademark of a third party without connection to DICOTA SCHWEIZ AG.
- Suitable for all devices with 2.5 x 6 mm slot
- Efficient anti-theft protection for slim notebooks (head diameter > 11mm)
- Coated multi-core steel cable, 2 m long and with a diameter of 4.4 mm
- Flexible workplace design thanks to the rotatable and swivelling closing head
- Rubber buffer ensures a seamless fit
- Easy installation with push-to-lock function
- Two keys are included
- Functional Velcro fastener for compact storage and transport
