Designed down to the last detail. First-class materials, best quality and ingenious interior. That's the Top Traveller PRO.
Travel '1st class' with Top Traveller PRO. The toploader bag reliably accompanies you everywhere and meets the highest standards of quality, functionality and protection: fitall system holds notebooks of various sizes, anti slip technology ensures your notebook and the shoulder strap do not slide and the light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. DICOTA's attention to detail makes this bag one of your most reliable business partners!
The fitall system separating wall in the notebook compartment lies protectively across your notebook and fits automatically to sizes from 14-15.6". The perforated and thus light EVA foam material in the sealable notebook compartment perfectly protects the edges of your device with a remarkable saving in weight. The bag is light and comfortable in your hand thanks to the high-quality genuine leather handles. The anti slip technology coating ensures perfect grip for your notebook in the compartment and the adjustable padded shoulder strap. Excellent protection for your iPad or tablet thanks to the EVA-shaped compartment with extra-soft nylex inner lining. Generous storage space for documents. The front pocket with key fob and insert pockets allows you to organize your personal equipment and provides space for additional mobile accessories. Zip compartment for IDs. Trolley strap can also be used as an additional document compartment. Bag bottom made from waterproof material.
