            The charging cabinet ensures that the devices are always ready and charged when they are needed. Safe storage and charging technology that is both energy- and resource-efficient - for use in a wide range of work and school environments. You can charge 10 notebooks or tablets at once with the cabinet, so you remain flexible at all times, and don't have to worry about not having enough sockets.
The pull-out and numbered compartments make it easy to assign the devices to individual users. The UV-C lamp ensures hygienic surfaces in an environmentally friendly way and without chemicals. Disinfection takes five minutes after activation and then switches off again automatically. The control panel can be used to control the UV light, the time and the charging period - from one to 24 hours. After the selected period has elapsed, the charging process comes to an end automatically. To protect the devices from overheating, the charging cabinet is equipped with a powerful and quiet fan. Maximum protection thanks to the robust steel housing and the visible double door, with built-in key lock. Up to two cabinets can be stacked to increase capacity to as many as 20 devices. The charging cabinet comes with country-specific power plug and connector strip for the laptops and tablets.
- Safely charge and store up to 10 notebooks or tablets
- Suitable for education and healthcare facilities, industry, meeting venues, hotels and catering
- The numbered, pull-out drawer makes it easy to access the devices
- Robust steel housing for maximum protection
- 2 cabinets can be placed on top of each other to increase capacity to as many as 20 devices
- Double door, 2-point mechanism with built-in key lock (2 keys included)
- Lockable rear panel (1 key included)
- Built-in fan and air vents to prevent overheating during charging
- Smart, digital control-panel for timer, UV light and time setting
- The charging period can be set to between one and 24 hours
- UV-C lamp disinfects the devices in an environmentally friendly and chemical-free way
- Easy and accessible cable management
- The charging cabinet comes with country specific power plug and connector strip for the laptops and tablets
- Surge protection switch
- Input: 220 V / 50 Hz / 10 A
- Output: 5-20 V DC, 3.5 A (max.) x 10
- Performance: 480 W (max.)
