The slim and lightweight input pen fits nicely in your hand while the grip surface gives optimum hold. Follow your intuition and operate touch applications with familiar movements. Writing, drawing and navigating with highest precision. At the same time, you prevent from disturbing fingerprints on your screen.
Immediately ready for use - simply turn on the pen and you can operate all applications without further installation. After 5 minutes of inactivity the pen will automatically turn into the energy-saving standby-mode. The built-in rechargeable battery convinces with 9 hours of runtime; the status of the battery can be tracked at any time using the indicator light. The complete charging of the pen takes about 80 minutes. The 1.5 mm thin tip allows smooth, continuous movements resulting in an accurate input. Thanks to the simple replacement of the tip you can additionally prolong the service life (spare tip is included in delivery).
- High-precision operation of touch screens
- Accurate handling thanks to handy shape and light weight
- Prevents from fingerprints on the screen
- Immediately ready for use - no installation needed
- Auto-Standby after 5 min
- 9 h battery life (fully recharged within 80 minutes)
- USB-C cable included
- Replaceable 1.5 mm thin tip (spare tip is included in delivery)
