Your outlet becomes smart
- The activation and disabling of connected devices such as lamps, the coffee machine, radio, can be time-controlled.
- Ready to use in no time: simply plug it in between the power socket and desired device.
- Finally, an end to unnecessary and high standby consumption of your devices.
- Measures the power consumption unobtrusively in the background and records it.
- Intuitive operation by browser, and a free app for smartphones and tablets.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
Never get cold feet again at your favourite seat. The devolo Room Thermostat provides your own individualised temperature where you actually spend time; after all, you usually don't sit directly next to the radiator. It equalises the temperature gradient between the radiator and your favourite seat. It functions simultaneously as a convenient "remote control" for all connected radiators in one room or on one storey. That's how energy saving is made even simpler with devolo Home Control!
