Your ideal temperature is always at your fingertips!
- Determine the exact room temperature at any time.
- Easy and central unit control of the room temperature (when combined with the devolo Home Control radiator thermostats).
- Comfortable temperatures exactly where you spend time, not just at the radiator.
- Manual temperature control directly on the thermostat at the touch of a button.
- Illuminated display to show temperature.
- Ready to use in no time: can be installed easily, without special tools or expertise.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
Never get cold feet again at your favourite seat. The devolo Room Thermostat provides your own individualised temperature where you actually spend time; after all, you usually don't sit directly next to the radiator. It equalises the temperature gradient between the radiator and your favourite seat. It functions simultaneously as a convenient "remote control" for all connected radiators in one room or on one storey. That's how energy saving is made even simpler with devolo Home Control!
