Discreet, alert, smart.
- Reliably identifies movements of people, animals and objects and sends text*, e-mail or app notifications.
- Versatile installation via adhesive film or screws (included in the box contents).
- Continuous brightness measurement, e.g. as feedback to the light controls.
- Intuitive operation by browser, and a free app for smartphones and tablets.
- Unobtrusive design for inconspicuous placement.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack.
The devolo Motion Sensor can be discreetly placed in your smart home and keeps a watchful eye on the surrounding area. It reliably detects every movement in an angle of up to 80 degrees and intelligently distinguishes between people, animals and objects (e.g. a door that moves because of a draft). The devolo Motion Sensor notifies you of the recorded movements via text or e-mail so you can stay informed even when not at home. Your smart home is always safely protected! Thanks to the infrared sensor, the Motion Sensor works just as precisely at night as it does during the day. Its individually configurable light sensor additionally makes it a versatile signal generator for a series of other Home Control components, such as the light controls.
