With the devolo 9225 dLAN 650+ AV2 600 HomePlug Starter Kit you can provide your home with a superfast network via the household electrical wiring and experience entertainment at the highest level, thanks to a high transfer rate at speeds of up to 600Mbps. Connecting your devices to each other is as easy as child's play - from the basement up to the attic, stable and continuous with no signal loss. Furthermore, the integrated Gigabit port provides a direct connection for a network-compatible device. The best part: with the integrated electrical socket (pass-through), no power outlet in your house is lost.
Complete HomePlug starter kit, includes everything you need to get started
The fastest connection at up to 600Mbps using the latest AV2 standards
Even higher performance and range with the latest Devolo range+ technology
New adapter design with integrated electrical socket and mains filter
The integrated socket ensures that no electrical outlet is lost
Compatible with all devolo adapters of the 200/500/600Mbps product range
Automatic encryption! Active protection against unauthorised access
Automatic phase shift: makes Internet access possible in any room
AV2 HomePlug Generation
Faster data transmission, longer range, new design: HomePlug pioneer devolo presents its first adapter of the AV2 generation in the form of this Devolo 9225 dLAN 650+ starter kit. The new chip technology, in conjunction with Gigabit Ethernet, enables communication at up to 600Mbps using a home's power lines for the first time.
Range+ Technology
By introducing the range+ Technology Devolo is showing a whole new generation of powerline adapters for even faster data transmission in the home network. A revolutionary innovation makes transmission rates of up to 600 Mbps a reality. Conventional Powerline technology uses only two of the three lines in the electrical circuit (phase and neutral conductor). range+ can also make use of the earth wire, thereby utilising the full physical potential of the power line for the first time. This not only achieves significantly higher transmission capacities, but longer range as well. Even secluded rooms in the basement or attic are now connected with a high data rate.
Power Saving And Mains Filter
The sophisticated look of this Devolo 9225 dLAN 650+ AV2 600 HomePlug starter kit meshes into a modern home environment seamlessly. One factor that makes this possible is the particularly energy-saving dLAN chip which generates little heat, allowing us to eliminate the cooling slits on the sides of the adapter. Consuming just 3.9 watts (maximum) during operation and 0.7 watts in automatic standby, this HomePlug starter kit is setting new top marks in this class.
The pass-through of this Devolo HomePlug kit design offers additional advantages: The integrated electrical socket ensures that no power outlet in a room goes to waste. In addition, the integrated mains filter drastically improves data transmission via dLAN Powerline.
Standard Warranty: 3-Years
