            The fastest high-speed home network - digital HD entertainment and 3D transmission throughout the home.
- High transfer rate of up to 500 Mbps
- For all types of bandwidth-intensive transmission
- Transmits multiple HDTV streams and even 3D movies reliably throughout the home
- Full compatibility with all 200AV HomePlug AV adapters
- Best energy saving mode: consumption is only 0.5 watts in standby mode
- 3 year manufacturer's warranty, as unit is designed, tested and certified in Germany
HD entertainment and fast home network in one: with speeds of 500 Mbps, the devolo dLAN® 500 AV mini is powerful enough to transmit even 3D movies to every room of your home. Without routing cables or WLAN picture stutter - simply over the electrical wiring. Connect computers, laptops, game consoles as well as Internet TVs and hard drive recorders to each other and to the Internet. The first powerline adapter of the latest generation is fully compatible with all 200 AV adapters, is extremely energy saving and, thanks to its flat, inconspicuous design, can be positioned anywhere.
