The world's smallest 15.6" (38.1cm) laptop packs powerhouse performance and a stunning InfinityEdge display.
The world's only 15-inch InfinityEdge display: The virtually borderless display maximizes screen space by accommodating a 15-inch display inside a laptop closer to the size of a 14-inch, thanks to a bezel measuring just 5.7mm , 59% thinner than the Macbook Pro.
One-of-a-kind design: Measuring in at a slim 11-17mm and starting at just under 4 pounds with a solid state drive, the XPS 15 is the world's lightest 15-inch performance-class laptop.
Here to help: Easily interact with your own personal digital assistant: Cortana. Using Cortana with a Dell PC equipped with Waves MaxxAudio Pro gives you a natural voice interaction experience.
Start it up: You'll feel like an expert from the get-go since your Windows Start menu is back in an expanded form. Plus, all your pinned applications will carry over so your experience is familiar, productive and better than ever.
Stay unplugged: Stay untethered for even longer: All Windows 10 devices now have Battey Saver to automatically conserve power so you can get more done for longer.
Brighten your day: With 400 nit brightness, the display is brighter than a typical laptop.
Touch friendly: Tap, swipe and pinch your way around the screen. The optional touch display lets you interact naturally with your technology.
The precision touch pad prevents jumping and floating cursors, while Accidental Activation Prevention puts a stop to unintentional clicks when your palm hits the touch pad.
A standard backlit keyboard illuminates your keys so you can stay productive in low-light or no-light rooms.
