Built to go easily wherever business takes you. The thin, lightweight design allows for maximum mobility, while the stylish aluminum casing and palm rest combine durability with a look of sleek professionalism.
Exceptional clarity
The anti-glare IPS display ensures sharp, detailed visuals from every angle for convenient group collaboration, while the built-in HD webcam and Waves MaxxAudio Pro allow you to collaborate remotely with crisp video and audio clarity.
Robust connectivity
A wide array of ports including USB 3.1 Gen 1 Type-A (x2), USB 3.1 Gen 1 Type-C (x1), HDMI and SD card reader allow you stay connected to a variety of devices.
Manageability you can count on
Easy access to Dell BIOS offers broad manageability to configure your system to your specifications.
Accident protection
A free-fall sensor locks the hard drive and prevents data from being lost or damaged if your laptop is shaken or dropped.
