Expect vivid, accurate color precision, ultrathin bezels and the widest color coverage to suit your professional needs with the Dell UltraSharp 25 monitor with PremierColor.
Enjoy exceptional color accuracy and consistency right out of the box with an extremely precise Delta-E < 2 factory calibration. The UP2516D monitor with PremierColor offers wide coverage of industry color standards with four color spaces, plus user-enabled color customization.
Outstanding view
Experience seamless dual or multi-monitor setup with ultrathin bezels. You can count on beautiful clarity with QHD resolution, plus consistent color across and ultrawide viewing angles.
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, PremierColor technology, stand lock, Multi-Stream transport (MST), adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, arsenic-free glass, Factory Calibration Report
56.77 cm x 20.03 cm x 39.8 cm - with stand
6.65 kg
DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , 4 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , DisplayPort output , Audio line-out
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Compatible with Windows 7
Plug and Play, DDC/CI, RoHS, BC1.2
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
48 W
Power Consumption (Typical)
130 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.77 cm - depth: 20.03 cm - height: 39.8 cm - weight: 6.65 kg , Without stand - width: 56.77 cm - depth: 5.16 cm - height: 33.79 cm - weight: 4.1 kg
