Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class G
Energy Consumption per Year
98 kWh
Diagonal Size
42.5"
Built-in Devices
USB 3.1 Gen 1/USB-C hub
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Pixel Per Inch
103.23
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
1.06 billion colours
Colour Gamut
96% sRGB
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
96.72 cm x 24.9 cm x 59.52 cm - with stand
17.6 kg
2 x HDMI , 2 x DisplayPort 1.4 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 90W) , Audio line-out (mini-jack) , 2 x USB 3.1 Gen 1 downstream , USB 3.1 downstream with Battery Charging 1.2 , USB-C 3.1 downstream
Mechanical
Display Position Adjustments
Height, swivel, tilt
Tilt Angle
-5/+10
Swivel Angle
40
Height Adjustment
60 mm
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-C cable , 1 x USB-C to USB-A cable
With stand - width: 96.72 cm - depth: 24.9 cm - height: 59.52 cm - weight: 17.6 kg , Without stand - width: 96.72 cm - depth: 5.9 cm - height: 56.44 cm - weight: 13.2 kg
