Dell UltraSharp U3421WE - LED monitor - curved - 34.1"
LED-backlit LCD monitor - 34.1"
Energy Class
Class F
Power Consumption (On mode)
31.6 W
Curved Screen
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare 3H hardness
Voltage
81.36 cm x 23.74 cm x 39.28 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DisplayPort 1.2, DisplayPort 1.4
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class F
Diagonal Size
34.1"
Curved Screen
Yes (1900R)
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
LED edgelight system
81.36 cm x 23.74 cm x 39.28 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , DisplayPort 1.4 , USB-C/DisplayPort 1.2 Alt Mode , USB 3.2 Gen 1 upstream (Type B) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 2 x USB 3.2 Gen 1 downstream , Audio line-out , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable , 1 x HDMI cable - 1.8 m , 1 x USB-C cable - 1.8 m
Input Voltage
31.6 W
31.6 kWh/1000h
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 81.36 cm - depth: 23.74 cm - height: 39.28 cm , Without stand - width: 81.36 cm - depth: 5.75 cm - height: 35.91 cm - weight: 7.52 kg
