            The Dell UltraSharp 27 4K Thunderbolt Hub Monitor U2725QE delivers image quality with a native resolution of 3840 x 2160, providing clear and detailed visuals. This monitor features a 27-inch diagonal size and a bright 450 cd/m2 image brightness, suitable for work tasks and multimedia consumption. With a contrast ratio of 3000:1 and viewing angles of 178 degrees, every detail is visible on the screen.
Equipped with built-in devices such as a KVM switch and USB 3.2 Gen 2 hub, this monitor enhances the workspace by allowing easy connectivity. The monitor supports USB Power Delivery up to 140 W, enabling fast charging for connected devices. Additionally, features like Auto Brightness Control and Low Blue Light technology contribute to comfortable viewing, making it suitable for extended use while reducing eye strain.
