Experience incredible color and superior black performance with a contrast ratio of 2000:1 on the 27" 4K monitor with IPS Black technology.
Enhanced eye comfort
ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
True brilliance
See fine details on this 4K monitor and enjoy truer-to-life color with 98% DCI-P3 and VESA DisplayHDR 400.
Designed with purpose
With a premium platinum finish and an elegant cable management system made to reduce clutter, it's the monitor built to match any workspace.
Easy to use
Navigate the menu and adjust screen settings with a convenient joystick control.
Built for comfort
Tilt, swivel, pivot and adjust the height of your monitor so you can work however you're most comfortable.
Environmental standards
This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as ENERGY STAR and TCO Certified Edge, and is EPEAT Gold.
Dell UltraSharp U2723QE - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/955176
Energy Class
Class F
Power Consumption (On mode)
25.9 W
USB 3.2 Gen 2/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
400 cd/m²
Contrast Ratio
2000:1 / 2000:1 (dynamic)
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
61.14 cm x 18.5 cm x 38.518 cm
6.64 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
815 kg carbon emissions
RoHS, BFR-free, PVC-free
3-year warranty
Bundled Services
3 years Basic Hardware Service with Advanced Exchange
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163.18
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
61.14 cm x 18.5 cm x 38.518 cm - with stand (lowest position)
6.64 kg
HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , DisplayPort output , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W, HDCP 2.2) , USB-C 3.2 Gen 2 upstream , USB-C 3.2 Gen 2 downstream (power up to 15W) , 4 x USB 3.2 Gen 2 downstream , USB 3.2 Gen 2 downstream with Battery Charging 1.2 , Audio line-out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x USB-C to USB-C cable - 1 m , 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
Input Voltage
25.9 W
25.9 kWh/1000h
Power Consumption HDR (On mode)
37.7 kWh/1000h
Power Consumption (Max)
220 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand (lowest position) - width: 61.14 cm - depth: 18.5 cm - height: 38.518 cm - weight: 6.64 kg , Without stand - width: 61.14 cm - depth: 5.433 cm - height: 35.301 cm - weight: 4.48 kg
