DisplayPort (HDCP) , HDMI (HDCP) , DisplayPort output (MST) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , USB 3.0 upstream , Audio line-out (mini-jack)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+21
Swivel Angle
80
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable , 1 x SuperSpeed USB cable
RoHS, BFR-free, HDCP 1.4, PVC-free
United States
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
23.8 W
Power Consumption (Typical)
30 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 18 cm - height: 39 cm - weight: 8.52 kg , Without stand - width: 61.22 cm - depth: 3.9 cm - height: 35.5 cm - weight: 3.92 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
647 kg carbon emissions
Total CF/unit Standard Deviation (kg CO2e)
127
Manufacturing (kg CO2e)
399
Logistics (kg CO2e)
61
Use (kg CO2e)
183
EOL (kg CO2e)
4
Total Carbon w/o Use Phase (kg CO2e)
463
PAIA Version
9/5/2018
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
