Stand not included with this monitor
The world's thinnest display border 6.05mm - Perfect for Dual & Triple Monitor Setups
See your work in its best light on the DellTM UltraSharp 24 Monitor - U2414H. Its upscale design features an amazingly thin 6.05mm border1 around a 23.8" Full HD display that delivers impeccable images.
With this incredible clarity across an ultra-wide 178-degree viewing angle comes the ability to pivot left-and right up to 90 degrees, so you can create a multiple screen arrangement with near-continual imagery between two or more monitors.
- Full HD resolution and ultra-wide viewing angle for crisp, clear viewing quality at virtually any angle
- Carefully colour calibrated at the factory, the DellTM UltraSharp 24 Monitor - U2414H features more than 96-percent sRGB colour space for impressive colour from the moment you set it up
- Great detail with a broad range of 16.77 million colours covering 96% sRGB
Bring your mobile devices to life on a large screen
Brilliance goes beyond the screen with easy connectivity to your favorite digital devices and fast USB charging capability.
A mobile high-definition link (MHL) port allows you to view high-definition content directly from your compatible smart phone or tablet. Three USB 3.0 ports enable fast data transfers while one high-current USB 3.0 port supplies twice the power for charging and powering compatible USB devices.
You can also connect your Dell UltraSharp 24 Monitor - U2414H to peripherals that require HDMI, DisplayPort or mini-DisplayPort connectivity.
Eco-conscious design
The Dell UltraSharp 24 Monitor - U2414H meets the latest regulatory and environmental standard .
- ENERGY STAR®
- EPEAT® Gold2
- TCO Certified Displays
Made with premium-quality materials, the U2414H is BFR/PVC-free (excluding external cables) and has arsenic-free glass, a mercury-free LED panel and a chassis made of more than 25 percent post-consumer recycled plastics.
Enhanced power managementManage power consumption wisely with PowerNap, enabled through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use
SPECIFICATION
- Manufacturer: Dell
- Viewing Angle:178/178 (°H/°V)
- Panel Type: LED (Backlit)
- Contrast Ratio: DCR: 1000:1
- Screen Size: 24"
- Pitch Size: 0.274 mm
- Response Time: 8 ms
- Connectors: 1 x Audio Line-Out,1 x DisplayPort, 2 x HDMI, 1 x Mini DisplayPort, 4 x USB 3.0
- HDCP: Yes
- Power Usage (Switched on): 16 W
- VESA: Yes
- VESA Options (mm): 100 x 100
- Widescreen: Yes
- Height Adjustable: Yes
- Monitor Colour: Black/ Silver
- Resolution: 1920x1080
- Refresh Rate: 60Hz
- Brightness: 250 cd/m²
- Warranty 3 year
