Connect your laptop and smartphone without cables for seamless connectivity.
Easy multitasking
Simultaneously display and edit content from your laptop and smartphone/tablet with a single keyboard and mouse and navigate across both screens with the same mouse.
Seamless transition
Switch smoothly between your smartphone and tablet to your monitor screen and back again.
Built for everyday business situations
Maximize your workday and multitask on the go in multiple ways. Transition between your laptop and smartphone and tablet and edit with a single keyboard and mouse.
Superb clarity and color
A beautiful 23.8-inch Full HD display ensures consistent clarity from any angle.
Better view
Experience an almost borderless view with an ultrathin bezel and an ultra-wide 178°/178° viewing angle.
Fully adjustable
Adjust height, tilt, pivot or swivel for comfortable viewing.
Easy connectivity
HDMI, audio line-out and four USB 3.0 ports make connectivity easy.
Dell UltraSharp U2417HWi - LED monitor - Full HD (1080p) - 24"
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
HDCP, LED edgelight system, stand lock, Dell Custom Color, Full HD wide-viewing angle (WVA), BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, Wi-Fi Direct, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, Dell Easy Arrange, Screencast
53.91 cm x 18.5 cm x 35.58 cm - with stand
5.12 kg
HDMI , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Cable management cover
1 x SuperSpeed USB cable - USB Type A to B , 1 x HDMI cable
Mounting Kit
Optional
Plug and Play, DDC/CI, NFPA 99, EDID compatible, IEEE 802.11ac
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
18 W
Power Consumption (Typical)
60 Watt
Power Consumption Stand by
3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.91 cm - depth: 18.5 cm - height: 35.58 cm - weight: 5.12 kg , Without stand - width: 53.91 cm - depth: 4.56 cm - height: 32.11 cm - weight: 3.28 kg
