Sporting the thinnest borders on a 27" curved monitor, a solid base and covered in a sleek piano black finish, this monitor fits ideally in any home environment.
A gorgeous view
The Dell 27-inch curved monitor offers great viewing comfort with its "wrap around" view, drawing you closer into the action and engaging you with its rich, powerful audio.
One display for many devices
Connect to a multitude of secondary devices via a wide range of ports.
Dell SE2716H - LED monitor - curved - Full HD (1080p) - 27" - with 3-Years Advance Exchange Service
Flicker Free technology, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
61.65 cm x 17.615 cm x 45.779 cm - with stand
5.96 kg
Bundled with
Audio
Speakers
2 x MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+21
Stand
1 x HDMI cable
Compatible with Windows 7
Plug and Play, WEEE, CECP
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
24.4 W
Power Consumption (Typical)
62 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 61.65 cm - depth: 7.128 cm - height: 36.62 cm - weight: 4.96 kg , With stand - width: 61.65 cm - depth: 17.615 cm - height: 45.779 cm - weight: 5.96 kg
