Connecting virtually with friends and co-workers gets a major upgrade with this monitor's built-in camera, noise-canceling microphones and dual 5W speakers. You'll enjoy amazing video clarity and crystal-clear sound.
The power of USB-C
Versatile USB-C connectivity delivers video, audio and data, and charges your laptop with up to 65 watts of power (even when the monitor is off) with the Always On Power Delivery feature. Plus, with just one cord, you'll have a clutter-free desk space.
Privacy when you want it
A super clear 5MP IR pop-up camera features facial recognition for convenient, instant sign-on. The camera stays hidden until you're ready for video chatting or selfies.
Comfort comes first
A height-adjustable stand and a monitor that tilts, swivels and pivots let you look and feel perfectly for all-day conferencing.
Engaging audio
Turn your monitor into the perfect entertainment center, with the help of 2 x 5W integrated speakers.
A stunning setup
It brings a blend of great style and quality into every living space with a modern, sleek design and the ability to save desktop space by hooking to the wall with a VESA mount.
Perfect ports
Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port.
Keep everything in order
Stay organized between applications, emails and windows on one screen using Dell Easy Arrange.
A stunning view
The three-sided ultrathin bezel design allows you to see more with less distraction for a better way to virtually meet your family, team, classmates, or even work-out coach and buddies.
Brilliant from every angle
In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle on the QHD (2560x1440) anti-glare screen.
Leisure gaming
Get smooth, tear-free experience with AMD FreeSync technology, featuring up to 75Hz refresh rate.
Next-level eye comfort
ComfortView Plus is an always-on, built-in low blue light screen that optimizes eye comfort by reducing potentially harmful blue light emissions while delivering excellent color accuracy.
Dell S2722DZ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
18.26 W
Adaptive-Sync Technology
AMD FreeSync
IR camera, USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
61.16 cm x 17.47 cm x 40 cm - with stand (lowest position)
Built-in Webcam
Sensor Resolution
5 Megapixel
Max Video Resolution
1920 x 1080 at 30 fps
Fixed focus
Audio Input
Two microphones
Microphone Features
Noise-cancelling
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB 3.2 Gen 1 downstream , Audio line-out
Mechanical
Display Position Adjustments
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
With stand (lowest position) - width: 61.16 cm - depth: 17.47 cm - height: 40 cm - weight: 6.86 kg , With stand (highest position) - width: 61.16 cm - depth: 17.47 cm - height: 51 cm - weight: 6.86 kg , Without stand - width: 61.16 cm - depth: 5.674 cm - height: 36.584 cm - weight: 5.18 kg
Shipping Weight
9.46 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
622 kg carbon emissions
Total CF/unit Standard Deviation (kg CO2e)
148
Manufacturing (kg CO2e)
398
Logistics (kg CO2e)
46
Use (kg CO2e)
173
EOL (kg CO2e)
5
Total Carbon w/o Use Phase (kg CO2e)
449
PAIA Version
1.3.2
Bundled Services
3 years Advanced Exchange Basic Warranty
10 - 80% (non-condensing)
