Immerse yourself in widescreen clarity and superb audio with a dependable multimedia monitor that connects you seamlessly to the entertainment you love.
Colour:
Diagonally Viewable Size:
60.5 cm
23.8" (23.8-inch wide viewable image size)
Optimal Resolution:
1920 x 1080 at 60 Hz
Aspect Ratio:
Widescreen (16:9)
Built-in Devices:
Integrated speakers
Pixel Pitch:
0.2745mm x 0.2745mm
Brightness:
250 cd/m2 (typical)
Colour Support:
16.7 million colours
Contrast Ratio:
1000: 1 (typical), Dynamic Contrast Ratio : 8 Million:1 (Max)
Backlight Technology:
LED
Viewing Angle:
(178° vertical / 178° horizontal)
Adjustability:
Tilt , built in cable-management
Flat Panel Mount Interface:
VESA (100 mm)
Response Time:
6 ms (gray to gray)
Panel Type, surface:
In-plane switching, Glossy
Display Type:
Widescreen Flat Panel Display
Display Screen Coating:
Glossy with hard coating (3H)
