With the expanded viewing area provided by an improved ultra-thin bezel, the Dell 23 Monitor offers a sleek, premium look and exceptional home entertainment experience.
Glossy, ultra-thin bezels, a classic black piano finish, and an aluminum painted riser create an elegant, modern design perfect for any home environment.
Easy, intuitive access
Intuitive capacitive touch buttons on the bottom bezel offer a sleek and seamless finish.
Sturdy stand
Easily tilt your monitor to your preferred viewing angle with the robust stand.
Maximum viewing area
Get the most out of your 23" (58.42cm) viewing area with bezels almost half as thin as their predecessor.
Impressive screen performance
Experience rich, accurate and consistent colors across a 178° ultra-wide viewing angle in Full HD 1920 x 1080 display.
Superb clarity
Minimize reflections with a sleek, remarkably clear screen.
Engaging audio
Dual 3W integrated speakers create the perfect audio complement to your viewing experience.
Plug and view
Get easy compatibility with both legacy and future-ready PCs via VGA and HDMI connectivity.
Reduced environmental footprint
The Dell 23 Monitor features PowerNap that reduces screen brightness or puts the monitor in sleep mode when it's not in use.
Dell S2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advanced Exchange Warranty
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Glossy, LED edgelight system, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver
52.07 cm x 17.99 cm x 40.42 cm - with stand
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , VGA , Audio line-in , Audio line-out
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+21
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x HDMI cable
Compatible with Windows 7
Plug and Play, DDC/CI
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
23 W
Power Consumption (Typical)
34 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 52.07 cm - depth: 17.99 cm - height: 40.42 cm , Without stand - width: 52.07 cm - depth: 5.42 cm - height: 31.16 cm - weight: 2.9 kg
