Flexible and user-friendly for work, school or fun. The Dell 21.5" touch monitor offers you 10-point touch capability with outstanding clarity and usability in a clean, efficient design.
Designed to encourage collaboration and give productivity a boost, the Dell 21.5" touch monitor offers a high level of user flexibility for work, school or entertainment.
Natural touch and superb image clarity
Tap, slide, swipe, turn, pinch and stretch with your fingers. The multi-touch capability is simple and intuitive when used with recognizing up to 10 touch points at once.
Efficient design
Conceived with a high priority on environmental efficiency, the Dell 21.5" touch monitor features low power consumption and environment-conscious materials.
Dell S2240T - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, VESA interface support
Stand, cleaning cloth, touch fastener strap
1 x HDMI cable , 1 x USB cable
Compatible with Windows 7
Plug and Play, DDC/CI
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 52.25 cm - depth: 20.57 cm - height: 37.08 cm - weight: 5.1 kg , Without stand - width: 52.25 cm - depth: 4.12 cm - height: 31.89 cm - weight: 3.4 kg
