Maximize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution, a sleek screen, and dual 3W integrated speakers.
Stylish design
Enjoy the elegance of thin, glossy bezels, a sturdy base, and intuitive capacitive touch buttons.
Reliable and easy to use
Built to comply with the environmental and regulatory standards, legacy and future-ready PCs with VGA and HDMI ports.
Dell S2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
Plug and Play
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
18.5 W
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.8 cm - depth: 17.99 cm - height: 38.57 cm - weight: 3.14 kg , Without stand - width: 48.8 cm - depth: 5.42 cm - height: 29.31 cm - weight: 2.6 kg
