Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity.
Flexible viewing features
The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort.
Excellent screen clarity
Every detail is bright and clear with the crispness of LED backlighting.
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio.
Energy-efficient design
With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
Dell P2014H - LED monitor - 20"
LED-backlit LCD monitor - 20"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
83%
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
47.05 cm x 18 cm x 35.42 cm
3.2 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
83%
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP
47.05 cm x 18 cm x 35.42 cm - with stand
3.2 kg
DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 2.0 downstream
Mechanical
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
United Kingdom
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 3.2 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
