Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity.
Flexible viewing features
The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort.
Excellent screen clarity
Every detail is bright and clear with the crispness of LED backlighting.
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio.
Energy-efficient design
With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
Dell P2014H - LED monitor - 20" - with 3-Years Advance Exchange Service
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance, arsenic-free glass
47.05 cm x 18 cm x 35.42 cm - with stand
4.35 kg
Bundled with
DVI-D , DisplayPort , VGA , 4 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
Display Position Adjustments
Tilt Angle
-5.5/+22
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x USB cable , 1 x VGA cable , 1 x DisplayPort cable
Plug and Play, DDC/CI, RoHS
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 4.35 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
