The Dell 19 monitor - P1914S adjusts to fit your style, whether you are at work or home. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. P1914S easily transitions from landscape to portrait orientation for optimal viewing of lengthy web pages with less scrolling.
Multiple connectivity options
A comprehensive range of analog and digital ports, and their accompanying cables, provides virtually all the connectivity options you'll need over the course of the day.
Sharp screen clarity
Every detail is bright and clear with the crispness of a LED backlighting.
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching (IPS) technology offers clear images with consistent and accurate colors from virtually any viewpoint.
Designed for work and home
Designed to help get the job done quickly, the P1914S is excellent for systems driving business or education applications.
Environment-conscious design
The Dell 19 monitor - P1914S meets the latest regulatory and environmental standards.
Energy-efficient design
Manage power consumption wisely with PowerNap, enabled through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell P1914S - LED monitor - 19"
LED-backlit LCD monitor - 19"
USB Hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
83%
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100/230 V (50/60 Hz)
41.14 cm x 18 cm x 37.02 cm
5.12 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Diagonal Size
19"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
83%
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PowerNap
41.14 cm x 18 cm x 37.02 cm - with stand
5.12 kg
DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 3.0 downstream
Mechanical
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
United Kingdom
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
16 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 41.14 cm - depth: 18 cm - height: 37.02 cm - weight: 5.12 kg , Without stand - width: 41.14 cm - depth: 4.65 cm - height: 33.64 cm - weight: 2.76 kg
