Affordable, professional performance. Affordable tower workstations for professional performance. Fully configurable and ISV certified with Intel processors and discrete graphics.
Fast is an understatement: power through intensive tasks easily thanks to the vigorous processors enabled for fast and stable performance.
Your work can count on it
Precision Workstations are tested to ensure the high-performance applications you rely on every day run smoothly.
Reach maximum potential
The Precision Optimizer, with SCCM centralized management, improves productivity and performance by fine-tuning your system beyond standard factory settings, and optimizes certified ISV apps.
Small form factor
The compact size with the option to expand as your business needs grow makes this ideal for maximum space saving without sacrificing power or potential.
Massive memory
Easily store and access large and complex 3D, multimedia and video project files with the speed and reliability.
4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in/microphone (1 rear) , 1 x audio line-out (1 rear) , 2 x DisplayPort , 1 x HDMI
GS, CECP
Pricing Type
Build To Plan (BTP)
Power supply
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition Multilingual User Interface (MUI)
