71.24 cm x 23.317 cm x 46.867 cm - with stand (lowest position)
9.6 kg
DisplayPort 1.4 (HDCP 2.2) , HDMI (HDCP 2.2) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1.8 m
With stand (lowest position) - width: 71.24 cm - depth: 23.31 cm - height: 46.867 cm - weight: 9.6 kg , Without stand - width: 71.24 cm - depth: 5.618 cm - height: 41.7117 cm - weight: 5.3 kg
Shipping Weight
13.4 kg
Environmental Standards
TCO Certified
TCO Certified Displays 8
ENERGY STAR Certified
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
