Transform how you work. Optimize your workspace with this monitor featuring USB-C connectivity, a small footprint and productivity-boosting features.
Dell P2719HC - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/344719
Energy Class
Class C
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
13.8 W
Daisy Chaining
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
60.99 cm x 18.5 cm x 39.43 cm
6.28 kg
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
623 kg carbon emissions
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
Energy Class
Class C
27 kWh
Diagonal Size
27"
Daisy Chaining
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Mercury free, arsenic free
60.99 cm x 18.5 cm x 39.43 cm - with stand
6.28 kg
DisplayPort , HDMI , USB 3.0 upstream , 2 x USB 3.0 downstream , 2 x USB 2.0 downstream , USB-C
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
Cable tie
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
13.8 W
13.8 kWh/1000h
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dell Display Manager
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 60.99 cm - depth: 4.28 cm - height: 36.3 cm - weight: 4.67 kg , With stand - width: 60.99 cm - depth: 18.5 cm - height: 39.43 cm
