ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
Convenient adjustability
Experience made-for-you comfort by tilting, swiveling, pivoting and adjusting the height of your monitor (150mm max) for optimal viewing comfort.
Simple customization:
Navigate and adjust your monitor screen settings with the easy-to-use joystick control.
Extensive connectivity
Conveniently connect to a variety of devices with extensive connectivity ports, including DisplayPort, HDMI, DVI, VGA and SuperSpeed USB 5Gbps.
Productive at every level
Easy Arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities.
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
Dell P2423 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
14.8 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.1 cm x 17.957 cm x 51.08 cm
5.56 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
3-Years Advanced Exchange Service and Premium Panel Guarantee
