The Dell 19 monitor - P1914S adjusts to fit your style, whether you are at work or home. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. P1914S easily transitions from landscape to portrait orientation for optimal viewing of lengthy web pages with less scrolling.
Multiple connectivity options
A comprehensive range of analog and digital ports, and their accompanying cables, provides virtually all the connectivity options you'll need over the course of the day.
Sharp screen clarity
Every detail is bright and clear with the crispness of a LED backlighting.
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching (IPS) technology offers clear images with consistent and accurate colors from virtually any viewpoint.
Designed for work and home
Designed to help get the job done quickly, the P1914S is excellent for systems driving business or education applications.
Environment-conscious design
The Dell 19 monitor - P1914S meets the latest regulatory and environmental standards.
Energy-efficient design
Manage power consumption wisely with PowerNap, enabled through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell P1914S - LED monitor - 19" - with 3-years Premium Panel Exchange service
