With full-power features in an incredibly condensed design, the OptiPlex 5050 lets you maximize your work environment. The Micro All-in-One stand and multiple mounting options create versatile, flexible solutions to any office situation.
Mount it and forget it
The OptiPlex Micro DVD/RW Enclosure lets you secure your micro PC directly on a wall or under a desk - with the added performance of a DVD/RW drive, so you can watch and share data easily with system, while the Micro stays out of sight.
Easy access
With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can stay up to date for longer, remaining viable for years to come.
4 x USB 3.1 Gen 1 (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x HDMI , 1 x DisplayPort , 1 x USB 3.1 Gen 1 (PowerShare) , 1 x VGA
Pricing Type
Build To Plan (BTP)
Power adapter
Power Provided
65 watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
Limited warranty - 3 years - response time: next business day
