Latitude’s superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
The gorgeous 13.3" Full HD display is anti-glare and features a narrow border - intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience.
High-caliber construction
Built with quality materials like magnesium alloy, the Latitude 7390 combines premium design with high durability.
Built to last
Your laptop can last as long as your tough workday with a long-hour battery life.
Advanced technology
Experience faster data speeds with a PCIe SSD, and higher transfer rates with Thunderbolt 3 connection.
