The Latitude 12 7000 Series is the thinnest and lightest 12.5" business-class 2-in-1, designed to go wherever work takes you. With an innovative magnetic connection for quick one-handed transitions, it's always ready to flip into tablet mode at a moment's notice.
Enjoy stunning resolution with the 12.5" Ultrasharp 4K UHD display, optimized for intuitive touch interaction. Every Latitude 12 is constructed with premium materials, including magnesium alloy and edge-to-edge Corning Gorillas Glass NBT, and is finished off with soft-touch paint.
Easily interact with your own personal digital assistant, Cortana, equipped with MaxxAudio Pro by Waves for a natural voice collaborative experience.
Multitask effortlessly with 6th Gen Intel Core M processors and up to 8GB memory. The Latitude 12's two Type-C USB ports and multi-card reader allow you to conveniently link and customize your accessories.
Industry-leading SSD PCIe storage offers lighter weight storage and up to 4x faster data transfer speeds. Built-in wireless technology with the latest long-range 802.11 ac wireless technology makes it easy to surf, stream and stay connected, while the long battery life allows up to 8 hours of unplugged power.
