An easily managed 15-inch laptop with top security features critical for small and growing businesses, all in a durable, reliable design.
Enhanced data protection: Data security is key in protecting your business and employees. Dell Data Protection is a suite of security software programs offered on each Latitude 3000 Series system. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks.
Safely communicate: Your Latitude 3580 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication.
Login with ease: Login to Windows Hello using biometric authentication with optional touch fingerprint reader or Dell infrared camera for easy and secure access.
Easy to manage: Dell Client Command Suite comes with a set of automation tools that assists in device monitoring, deploying images, updating and more, to maximize your hardware and software investments and save time.
Outstanding reliability: Your Latitude 15 features a durable, built-to-last chassis that has undergone extensive military-grade MIL-STD 810G testing to ensure your system can withstand real-world conditions.
Power your workday: 7th Gen Intel Core i7 processors deliver the power you need for optimum productivity. The DDR4 memory boosts transfer rates while using less voltage, making your Latitude run faster and more efficiently.
Flexible connectivity: VGA, HDMI, RJ-45 and USB Type A ports let you go dongle free and accommodate your legacy connections.
Work together with ease: The extended 180-degree hinge is smooth, flexible and durable so you can collaborate effectively.
Take your work with you: At less than 24mm thin and weighing less than 2kg, your Latitude is travel ready.
