You have everything you need to run your projects with powerful, efficient fifth-generation Intel processors and fast, reliable solid state storage.
Longer battery life
The Latitude 12 Rugged Tablet powers you through a full shift of projects on the go.
Easy outdoor readability
Work never stops, regardless of environment. See clearly in direct sunlight on a crisp, 11.6" multi-touch display that responds even while wet or when wearing thick gloves.
Bring the heat
Experience peak performance even in high temperatures with fourth-generation QuadCool fan based thermal management system that combines passive and active cooling.
Outstanding reliability
The Dell Latitude 12 Rugged Tablet is subjected to rigorous testing to ensure world-class dependability in the most demanding of conditions.
Dell Latitude 12 Rugged Tablet 7202 - 11.6" - Core M 5Y71 - 8 GB RAM - 128 GB SSD - with 3-year ProSupport
