See your work in superb FHD clarity. IPS technology delivers consistent color and picture quality across a wide 178°/178° viewing angle.
Easy on the eyes
This monitor has a flicker-free screen with ComfortView, a software feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over an extended period of time.
Convenient connectivity
Connect to current and legacy systems via HDMI, VGA and DP ports.
Maximize your desktop
Cut clutter with space-saving features like a compact stand and improved cable management that hides cables while complementing any workspace.
Clean, simple design
A slim bezel adds a modern look.
Adapts to your needs
Make your workspace your own with VESA-compatible mounts and stands.
Dell E2422HN - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
55.264 cm x 17.1 cm x 42.035 cm
3.55 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
RoHS, NFPA 99, BFR-free, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Service
Vostro 14 5410, 15 3510, 15 5510
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Mercury free, arsenic-free glass
55.264 cm x 17.1 cm x 42.035 cm - with stand
3.55 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover
1 x HDMI cable
Input Voltage
16 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption (Max)
28 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.55 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 331.61 cm - weight: 3.2 kg
